How do I exclude a device from the splash page?
TooTallJack
I have a device that is on our "Guest" network that I want to be able to exclude from having to access the splash page and that just is on that network
How do I do that?
3 REPLIES 3
Adam
Re: How do I exclude a device from the splash page?
Setting the policy on the device to whitelist will exclude them from the splash page but will also exclude them from any traffic shaping and other restrictions.  So use that carefully.
HodyCrouch
@Adam is correct.
You also have the option of creating a Group Policy that only changes the splash behavior.
Network Wide > Group Policies > Add a group
Set Splash to 'Bypass' and leave everything else as 'Use SSID Default'.
When you locate a client in the Network-Wide > Clients page, use the 'Apply Policy' option to apply your group policy.
Nolan
Not to highjack this thread but I was wondering if anyone has had any issues with creating a group policy and applying the splash page bypass but it not working properly? I'm trying to think of some troubleshooting steps but I'm not sure where to start.
