How close together can two outdoor MRs be?
Wanting to add another MR 74 to this mount
Will have two patch antennas (2g/5g) pointing the other direction in the direction of the finger pointing
different channels obviously.
are they too close?
5 REPLIES 5
Re: How close together can two outdoor MRs be?
The wavelength is about 122mm.  So if possible I would try and space them more than 122mm apart.
If you want to get more complicated, try and avoid spacings that are a multiple of 1/4 of the wavelength as well if they are close together.
Dude you are something else! Ok I think we will build a new mount about 6 feet away anyway. Thanks!
If you antenna are directional you should be ok but space as mentioned already. 122mm isn't alot so maybe mount to a thick piece of wood or something.
My unofficial rule of thumb for vertical separation is 4 feet minimum. Can't remember where I read that from. Can't remember most things these days. Getting old is fun 😃
Nolan Herring | nolanwifi.com
TwitterLinkedIn
nice roof, beautiful location.
