How can you get a summary report for an individual ssid and an individual AP?
Tspan
We would like to access a summary report that gives details of one SSID and one particular AP in the network, we are looking for a guide to what types of information customers are accessing while visiting the museum.  Currently can only see a summary report for one SSID but all the APs on the network.
5 REPLIES 5
kYutobi
You can "tag" and AP and give it a name for example you can give 5 AP's the same tag name if you're collecting data for all 5 or you can just tag 1 AP if you want singular.  Do this by going to Wireless/Access Points/ Pick your AP there should be a tag option there.
Enthusiast
@kYutobi,
You are 100% correct! I didn't realize that there was a new version of the Organization > Summary Report so I never saw the additional options for filtering there! Nice feature, not sure how I overlooked it.
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
kYutobi
Just glad to be of help Wade. Cat Happy
Enthusiast
I have applied the tag to an AP  but the summary report is still not giving any usage statistics.  I only applied the tag to a single AP that is at a remote location.  There have been clients connected, but the summary report is still all zeroes.  Does the AP need to reboot or am I missing a save button?  The tag does appear on the AP config.
WadeAlsup
Hi @Tspan
For now, I think it's a limitation of the design of the Traffic Analytics page. I wish they would add more filters here, such as the ability to specify a single Meraki device or filter by Tags.
I think it would also be nice to be able to filter the Network Wide Clients page by the Connected To field. This could get us there as well. I guess I'll just keep submitting wishes...
