Since moving to an all Meraki system I have been unable to connect my HP Envy 5530 wireless printer to the wireless.
Previous system was an Apple Time Capsule. When switching I did have issues with Wireless sound speakers and smart bulbs. But I have sense resolved that.
Any suggestions?
MX64, MS220-8P, MR33
Solved! Go to Solution.
Found the issue
I had to change 802.11 r to adaptive and it works now
try a ssid with wpa+wpa2, no band steering, lowest minimal bandwith.
See if their any are firmware updates for your printer.
Tried that and no change
Device does show it connects to the AP but then I receive an error of connection failed.
changed one ssid to lower density and dual band operation (with no band steering) also included wpa+wpa2
firmware is the latest
Found the issue
how did you do those changes?
