Eduroam setup
mrshahin
Eduroam setup
Hi Guy's,
We have a Meraki wifi network in our organization and it is already setup and running.
Now we would like to use the meraki with Eduroam as well, I found a artikal on how to setup this, but still I have some questions and hope you guy's can help.
Should we before confiure the RADIUS server create a new SSID? or setting the RADIUS server is enough?
Also de artikal says chose WP2 Enterpris but I see only this:
Accepted Solutions
Re: Eduroam setup
Enterprise with> choose for my radius server
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring_RADIUS_Authentication_...
If you want to test first i would create a New ssid first to get it working
2 REPLIES 2
Re: Eduroam setup
Bruce
Re: Eduroam setup
Whether you need a new SSID or nor depends on how your Eduroam service is setup. I know here all the participating education institutions have a separate SSID called EDUROAM, specifically for this service.
As @ww stated, under Network Access for the Eduroam SSID, select ‘Enterprise with’ option and then ‘my RADIUS server’. You’ll then be able to enter your RADIUS server details further down the page.
