What is the best way to implement download quota on Meraki MR devices? You can do firewall & traffic shaping but how about download quota for each user?
@BTee there is nothing native in the Meraki Dashboard for daily download quotas, however you could perhaps accomplish this via API. For example you could write a script that leverages the daily usage history API endpoint (https://dashboard.meraki.com/api_docs/v0#return-the-clients-daily-usage-history) and have some logic in your script that then calls, if necessary, the API endpoint to update the group policy that applies to that client (https://dashboard.meraki.com/api_docs/v0#update-the-policy-assigned-to-a-client-on-the-network) and in that group policy you can configure what you like, such as more restrictive traffic shaping, complete blocking, or blocking specific apps for example. Just a thought, hope that might help.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_669277556709f5","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_669277556709f5_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_669277556709f5_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_669277556709f5_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_6692774b50e910","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
