Does MR74 feed its antenna I/O back through its ethernet port in Repeater Mode?
If I have a MR74 thats on a building on the receiving end of a long haul across a field, so connected via 5ghz directional antenna to a gateway MR74, if I power this receiving MR74 from a PoE+ switch, will the MR74 send the internet into the switch such that anything I plug into the switch is bridged to the network? I believe the answer is yes but wanted to make sure.
Followup question - if yes, if I should plug another AP say a MR42 into that same PoE+ switch, it would probably go look for an actual gateway over wireless before using the internet connection being provided by the MR74's ethernet port, correct? Would it properly detect the network communication and traffic coming over the ethernet port AND wireless with the MR74?
Made many a network over the years, now admin of a retreat center with some of this fine Meraki hardware.
1 REPLY 1
Re: Does MR74 feed its antenna I/O back through its ethernet port in Repeater Mode?
I believe this is the help doc you're looking for:
https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Extending_the_LAN_with_a_Wireless...
In short, connecting the switch will work. But then also connecting another AP will not (unless you put another MX there and build the "supported" topology shown in the link above.
No VLANs transferred over the wireless mesh bridge is also an important limitation.
