Device Keeps disconnecting and reconnecting
CyberTechs
Hello All,
We have one device that keeps disconnecting and reconnecting.  Below are the logs.  Any idea what's happening?
RSSI is great at 50
Device is a linux based device.
Aug 26 08:14:55802.11 association
channel: 11, band: 2, rssi: 52
Aug 26 08:14:55802.11 disassociation
previous authentication expired
Aug 26 08:14:54WPA authentication
Aug 26 08:14:54WPA deauthentication
radio: 0, vap: 6, client_mac: 8C:F6:81:00:58:D2
Aug 26 08:14:54802.11 association
Aug 26 08:14:51802.11 disassociation
unknown reason
Aug 26 08:14:51WPA deauthentication
Aug 26 08:14:29WPA authentication
Aug 26 08:14:28WPA deauthentication
Aug 26 08:14:28802.11 association
channel: 11, band: 2, rssi: 53
Aug 26 08:14:28802.11 disassociation
Aug 26 08:13:50WPA authentication
Aug 26 08:13:50WPA deauthentication
Aug 26 08:13:49802.11 association
channel: 11, band: 2, rssi: 51
Aug 26 08:13:49802.11 disassociation
Aug 26 08:13:49WPA authentication
4 REPLIES 4
KRobert
What MR do you have and what version are you on?
CMNO, CCNA R+S
CyberTechs
Thanks. I should have included this from the get go.
MR36's and
FIRMWARE
Up to date
Current version: MR 28.6
Some more information:  The vendor took the device back to his workshop and had no issues connecting to his in-house wifi (Non meraki).
CyberTechs
Some more logs:
Aug 26
08:03:33
Disconnected from SSID Summit from AP AP05.
CHANNEL
11
BAND
2.4
GHz
SNR
50
dB
802.11 REASON (CODE 2)
Invalid authentication
Aug 26
08:03:28
CHANNEL
11
BAND
2.4
GHz
SNR
51
dB
Aug 26
08:02:38
Unexpectedly disassociated, but the client had a successful connection to SSID Summit for a minute on AP AP05.
CHANNEL
11
BAND
2.4
GHz
SNR
51
dB
TIME TO CONNECT
3890
ms
How is the network congestion for 2.4 GHz at that location? Does the device support 5 GHz?
I wonder if perhaps one of your neighbors might not be playing nice and causing de-auths.
