Deny access to ssid
RVilhelmsen
Deny access to ssid
I have some users connecting to a ssid (let´s call it NetworkA) where authentication is done with Microsoft radius to AD.
Is it somehow possible to automatic deny access to other ssid for a device that´s connected to NetworkA?
Regards
Robert
12 REPLIES 12
kYutobi
What you can do is block access to SSID from the Clients tab. You can import all the MAC addresses and block them.
Enthusiast
it´s a way, but not a pretty way 😃
GaryShainberg
@RVilhelmsen why would a user, that has an active connection to network A SSID then try and connect to the second SSID also how would you having them authenticate on the second ssid ?
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
maybe some users connect to a less restricted network 😉
Then I would use group policies, once a user has connected to an SSID, assign the policy and then every-time that device connects the policy will control wheat they can do and where. they can go
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
how can i block access to other ssid from a group policy?
OK, let me set up a lab to have a look at the best way to do this for you, may take a couple of days, if thats OK
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
Thank you - that´s super fine.
I am stuck and can´t figure out a automatic way to do this.
Use dot1x to authenticate the second SSID, and configure RADIUS not to allow the first group of users to connect to it.
I can´t as the other ssid is a guest ssid.
Pulkit_Mittal
Hi @RVilhelmsen,
I believe tagging can be an alternative for management across SSID for users in different AD groups, similar to https://documentation.meraki.com/MR/Other_Topics/Using_Tags_to_Broadcast_SSIDs_from_Specific_APs
Thanks!
Use one SSID with iPSK, default it to public VLAN on the RADIUS server and set it so that known MAC addresses go to corporate VLAN.
