Creation informations of form by guest
akram
Hello all ,
I am beginner in the world of cisco Meraki , and i would your help , my customer request the scenario , when the guest user connect in AP , the page must be displayed with a form contain the fields :
  • Civility
  • Name:
  • Prénom
  • Phone number
  • Email :
  • Preferred city :
  • Type of desired property: Apartment / Lot of land / Villas
  • Budget :
  • Surface :
All of these fields must be completed by the guest .
can you help me to implement this scenario.
Best regards
Akram
You can create and use custom portals.
https://developer.cisco.com/meraki/captive-portal-api/
akram
Thank you for your reply
Boundless
Hi Akram,
Thanks to the captive portal API, you can design by HTML and host your own splash page.
You can also use an external service so that you don't have to do customer development. You can find tech partners specialized in Guest Wifi solutions here : https://apps.meraki.io/apps/?category=Guest+WiFi
Our solution, Boundless Guest, is among the list.
Best,
Noel
Noel-Edouard Chenu
