Hi there,
I'm quite new to the whole Meraki thing and cloud-managed networking.
My current setup only consists of two MR32 and one MS220.
In the future I want to use template-based network creation, but I've noticed, that each network only gets assigned the SSIDs which are defined in the template.
Our sites should look somewhat like this:
Site 1:
Site 2:
Could somebode give me a hint to how I will be able to replicate this idea in the dashboard?
I don't want to create a new network from scratch for each site.
Thanks in advance.
I don't think you can locally override that setting.
What you could do is define all the SSIDs you need in the template, and then limit SSID availability based on tags. Then just add a different tag to your MR's per site.
That's indeed a limitation.
Can you share a bit more info about the reasons for having a specific SSID per-site?
Ever thought about doing RADIUS accounting in combination with (Meraki) group policies?
No need for any separate SSID like that.
More info:
