Search instead for
Content Filtering/whitelisting
Have a bunch of MR 42 along with MX100 and MS switches.  About 5 SSIDS, one of them needs to have all internet blocked with the exception of a few specific sites. Didn't see a way to do that with the Layer 7 rules.  Can this be done? (each SSID is sep vlan)
Accepted Solutions
Re: Content Filtering/whitelisting
Well you could do it like this... You first define a group policy with the rules you need. Something like this:
Then, in the Addressing & VLANs section in the MX, in the VLAN you want to restrict, you select the group policy you just created in the dropdown:
2 REPLIES 2
so simple, thanks!
Points Contest
Join us for a month-long contest with heaps of swag to win!
Learn More ›
