Consent message in Sponsored guest login page
RayIT
Is it possible to display a consent message in the sponsored guest login?
It is working in other splash page options, but not in the sponsored guest login.
6 REPLIES 6
Already checked this link.
The issue, that this not working in our environment.
Its works in "Click through", but when I'm checking Sponsored guest, the consent message disappearing.
I just tested it and it is working as expected.
I suggest you open a support case.
Any way, you can customize the HTML.
This is strange,
just received reply from meraki support:
Are you sure, that you checked "Sponsored Guest  login" option?:
You might have to resort to "you can customize the HTML" as mentioned by @alemabrahao .
RayIT
Guys, you cannot customize anything related to the consent message in HTML.
Please try it yourself and send screenshots here.
