Connectivity Figure
RumorConsumer
Connectivity Figure
Hi there
In the dashboard, there is a Connectivity % that you can add to your list of metrics to view in the client list. It occurs as a percentage. Anybody know how this is calculated and precisely what it indicates?
6 REPLIES 6
Where are you seeing this?
in the client list. you can add a column called "Connectivity".
As a side note, I recently reported the fact that it shows you the *capable* channel width here instead of the *actual* channel width of each device. There is a link called "Capabilities" in the individual client page that should reveal this information but in this list I believe it should tell you what the actual channel width Right. Now. actually is.
@RumorConsumer
When I hover over that field I get this popup.
So if your timeline is set for "for the Last day" I would say its in regard for the last 24 hours.
@BlakeRichardson Awesome thank you. I think my question is more since this is a percentage, what precisely is it measuring? Attempts at association?
@RumorConsumerI think it just shows how long they have been connected, i.e. if a device has been connected for 12 hours and the timeframe is set to last day then it would show 50%.  Or does this not tally with what you see?
RumorConsumer
That seems to match!
