Configuring MR33 for large Deployment
Netwow
I am looking for a deployment guide for Meraki APs in a warehouse.  I see there are high density CVDs . I need this for training purposes.
CVD = Cisco Validated Design (you can Google "Cisco CVD").
What is the height of the roof in the warehouse?
2 Replies 2
BrandonS
CVDs?  Not sure what that is.
MR33 is not designed for high density itself, but on the other hand warehouses are not usually high density wireless usage.  More likely you want to consider the MRs with external antennas to aim signal down tall aisles in a warehouse or toward the floor if you are forced to mount them very high above the clients.
