Clients Disconnecting after 40 minutes from Mr-56 and then will slowly reconnect
AugieV
I have a classroom with a Mr-56 AP that is dropping all clients (about 30) after 20 to40 minutes or so.
All those clients will then attach themselves to  an Mr-42 in the class next door so it is now serving around 55 clients
which slows down those clients.
If I don't do anything the clients will start to come back to MR-56 slowly. If I reboot the Mr-56 they connect right away.
Steps that I have tried
I have swapped out the Mr-56 same issue.
Swapped ports, swapped patch cables  same issue
Ran a new Cable to a different switch same issue.
Any comments or ideas would be gladly accepted
Next Step is to put a different model AP in that room.
11 REPLIES 11
Bgammon
Re: Clients Disconnecting after 40 minutes from Mr-56 and then will slowly reconnect
It’s not something like a dhcp lease expiring?
Any of 802.11r or k enabled on the ssid?
Dfs event?
Channels/power aren’t changing?
@AugieV a few more details please:
  1. what firmware are you running
  2. how is the SSID configured: bridged, L3 routing or Meraki DHCP
  3. how are the devices authenticating: PSK, 802.1x etc.
  4. Are there any alerts in the AP log to suggest interference or channel changing from DFS etc?
To test whether this is a malicious student if you swap the MR42 and MR56 - does the issue stay in the same classroom (student issue) or follow the MR56 (MR56 issue, possibly firmware)?
AugieV
Hi CMR
1. Firmware 27.6
2. It is not SSID Specific we actually use all 3
3. PSK authentication
4. Nothing that would suggest interference. I do get a lot of 802.11 disassociation unknown reason even though the client has not moved.
AugieV
Hi Phillip
I will be swapping the Mr-56 for an Mr-42 this afternoon lets see what happens
AugieV
Thanks, Bgammon
No its not a dhcp issue
I do not have 802.11r or K enabled also its not SSID dependant
I don't think its a dfs event I have 134 AP's and I have not seen any dfs events and I have set it on auto-select and it does not change channels very often.
AugieV
Switching the Mr-56 for an Mr-42 did the trick its been working without an issue for 3 days.
Any Ideas
Clients don't like WiFi 6?
What chipsets are in the client devices, some work better than others when connecting to WiFi 6 APs.
I recently just had a customer with an issue with MR56's - and it turned out to be the power saving settings on the NIC on the notebooks.  You want to configure the client NIC to run always at "Maximum performance".
You can automate this change on Windows 10 by running these two commands (while connected to WiFi):
powercfg /SETDCVALUEINDEX SCHEME_CURRENT 19cbb8fa-5279-450e-9fac-8a3d5fedd0c1 12bbebe6-58d6-4636-95bb-3217ef867c1a 0
powercfg /SETACVALUEINDEX SCHEME_CURRENT 19cbb8fa-5279-450e-9fac-8a3d5fedd0c1 12bbebe6-58d6-4636-95bb-3217ef867c1a 0
AugieV
We use Apple IPads 6th and 7th Generation but it does not discriminate it just will drop all 30 connections at once and move to the nearest AP. If I see an Mr-56 with 0 clients and I reboot the AP it will reconnect all the clients, Otherwise, it will start to slowly reconnect the Clients.
It is not client or SSID specific but they are mostly apple products Macbooks, Ipads, Apple Tv's.
AugieV
Not sure if I can do that to apple IPads but I will look in our MDM.
