Client has negotiated to either 802.11ax or 802.11ac in the dashboard ?
degarris
Is it possible to tell if a client has negotiated to either 802.11ax or 802.11ac in the dashboard ?
GIdenJoe
If a client is 802.11ax and the AP is too then they will have an ax session.
It is however not shown in dashboard like you would see on a regular Cisco controller what standard has been used, etc.  Only the dot1x policy is shown and basic stuff like SNR.
2 Replies 2
KarstenI
On the clients page we have the "Capable Wi-Fi standards" that indicates what the client can do. But I donÄ't think that we really can conclude that the actual connection is ax or ac. But it the client is capable of ax, it typically should be connected with ax.
What I am missing more is the information if the client used WPA3 or WPA2 if I have enabled both on my SSID. Without this information I have no idea when it if time to really disable transition mode.
GIdenJoe
