Changing this message
athan1234
Is it possible to change this message in any way?
When a user tries to access using a mobile device, Meraki displays this notice, indicating that I have blocked the access. I want to change it.
15 Replies 15
You can try edit or customize the HTML on the Splash Page configuration:
https://documentation.meraki.com/MR/MR_Splash_Page/Custom_Splash_Page_Themes
I'm not sure that screenshot is from a splash page.
It might be the block page that a user gets when trying to access content that has been blocked (such as by content filtering).
If so - the page can not be changed.
Yes, you can change.
athan1234
Hi
yes that right .
So it is impossible to change it ?
@PhilipDAth
You can customize the HTML too, and It will work with no problem. 🙂
How can you customize the HTML for the general block page (not splash page)?
You need to create a new custom theme, edit It then edit blocked.html.
There is a variable called $MERAKI:NETWORK_ADMIN_BLOCKED_YOU$, and you can change It for a static message.
That is for splash pages with a captive portal, not for a general network block (such as by content filtering).
But we are talking about the splash page, look at the image that he sent 😅
athan1234
I succeed, yet the error remains.
Any device connected to the SSID just PC is the concept.
The default message that appears when a user tries to connect to your mobile devices is The admin restringedXXXX.
I replace this message with:
This network does not support mobile devices.
I believe it to be impossible.
I change the HTM it is not work
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>$MERAKI:NETWORK_NAME$</title>
<style type="text/css" media="screen">
$MERAKI:INLINE_MAIN_CSS$
</style>
<meta name="viewport" content="width=device-width,initial-scale=1">
</head>
<body>
<div id="content">
<div id="container">
<div class="header">
<div id="icon_cell">$MERAKI:NETWORK_LOGO_IMG_TAG$</div>
</div>
<div class="login-error">
<p>ESTA RED ES DE USO EXCLUSIVO PARA ORDENADORES</p>
</div>
<div id="blocked">
<h1>$MERAKI:WELCOME$$MERAKI:NETWORK_NAME$</h1>
<p>$ESTA RED ES DE USO EXCLUSIVO PARA ORDENADORES$</p>
</div>
</div>
<div class="footer">
<h3>POWERED BY</h3>
$MERAKI:CISCO_MERAKI_SMALL$
</div>
</div>
$MERAKI:MERAKI_JS$
</body>
</html>
I thing it is not the smae message
Have you configured the Ssid to use the custom page that you configured?
But I agree with you, there is no way to customize the general block page. 🙂
