Unless their documentation is out of date, which is possible, I don't think you can change the default values for Auto-channel on the 2.4GHz radios. Here is what I found:
Autochannel on 2.4 GHz only uses channels 1, 6 and 11. Administrators can remove only one of the three channels. If non-standard channels need to be used manual overrides can be done from the Overview page.
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
LITHIUM.Form.resetFieldForFocusFound();
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6332839b53de0b","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6332839b53de0b_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6332839b53de0b_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6332839b53de0b_2","feedbackSelector":".InfoMessage"});
LITHIUM.AjaxFeedback(".lia-inline-ajax-feedback", "LITHIUM:hideAjaxFeedback", ".lia-inline-ajax-feedback-persist");
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_6332839b53de0b","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
