Cast stopping to work after upgrade
I used Spotify cast in my local LAN for a long time. Since yesterday (after an upgrade) I'm not able to cast. I see the (in Spotify devices menu) the devices (on my laptop, on my mobile too) it looks getting connected but after 3-4 sec it drops the connection. I tried 3 different (chrome)cast enabled devices.
The Wireless in bridge mode as was before.
Thanks,
bandi
5 REPLIES 5
Re: Cast stopping to work after upgrade
Hi @Bandi , not seen this myself but why not roll the firmware back?  Then raise a ticket with support to inform them of what broke.
Darren O'Connor | uccert.co.uk
Good point @UCcert , but I did the upgrade because the site-to-site VPN (the SSID tunneled into it) stopped working, and needed to upgrade everything to works again. So if I roll back I lose the tunneled SSID... or I had to find which automatic upgrade (?) occurred the VPN problem and rollback that too.
But thanks I'm thinking about it (now I stream on Airplay..)
@Bandi what version were you on and what are you on now, also what device is it?
@cmrMR 26.8.1 → MR 27.5 I have MR33, MR30H APs
After 2 days it has started to work... perhaps it was an IP addressing refreshing issue? Never will be known I think.. But thanks for the help,:)
