Captive-Portal Identification in DHCP and Router Advertisements (RAs)
eesquer
¿There are any plans to integrate the DHCP or IPv6 Router Advertisement (RA) options for Captive Portals, when using the NAT option on MR AP´s?
These options are part of a new standard that allows your access point to advertise that it is “captive” when a device first joins, rather than rely on traffic interception.
https://datatracker.ietf.org/doc/html/rfc8910
Greetings.
2 REPLIES 2
Inderdeep
Re: Captive-Portal Identification in DHCP and Router Advertisements (RAs)
@eesquer : not yet there i guess
Regards
Inderdeep Singh
www.thenetworkdna.com ( Awarded by Cisco IT Blogs award 2020)
You could try opening a ticket with Meraki to join the IPv6 beta, and then submit the feedback directly to the beta team.
