Can we use MR Wireless AP with traditional switches 3650 or we required all MS switch in the network
Naresh_Bhardwaj
Can we use MR Wireless AP with traditional switches 3650 or we required all MR switch in the network
4 REPLIES 4
KarstenI
You can use any switch. Having PoE would be nice to power the APs but is also not necessary as you can power them with external power supplies and/or power injectors.
But using Meraki Switches with Meraki APs give you a better visibility into your network as they integrate in the dashboard.
RupertDot11
If you are asking whether Meraki switches (MS) are required for Meraki AP (MR) to work, the short answer is No.
But you do need to have a source of POE, which can either be Cisco Catalyst or Meraki MS.  You should pick a switch that supports 802.11at
Thanks Rupert for your quick response
If we can use the traditional switch that support 802.11at is there any limitation of using traditional switch with POE over Meraki MS in prospective on Meraki dashboard management like..config AP..backup.. or is it possible to configure Traditional switch with POE through Meraki Dashboard.
If we have the below network
Meraki Dashboard >  MX -->  Traditional switch with POE --> MR > End User.
You cannot configure a non-Meraki switch thru the dashboard. You would have to configure that the traditional way (cli, etc).
the obvious advantage of all-Meraki stack is that you’d get complete visibility thru the dashboard.
