Hi, i need to download monthly summary report on meraki console to excel file. i use export button, but nothing happened. i tried to change time frame , different browser/pc, use another network. it still isnt work.
Just tested using Chrome and it exported fine.
Edit: I also noticed you can click the little e-mail button next to the export and schedule it so send regularly if that is data that you need often.
I haven't tried before, so decided to give this a test just now. I'm guessing I have a similar issue. When I click export I get the following:
It's been sitting there for a good 15-20 minutes now. Haven't had time to look, but I'm guessing my firewall is blocking it in someway.
Will get back to you when I can.
Edit: E-mailing the report works fine in the meantime.
I didn't get a chance to look at my firewall, but mine is also working now with no changes made.
Good to hear it is working again. Must have been a serverside issue.
