Can I relocate access points to a new organization ?
Lirios
Hi everyone,
I need to relocate every access points which are present in an organization to a new.
Of course, when i say "relocate" this means on a dashboard.
Knowing that i'm just network admin on organization,  I have fewer rights compared to the Organization Admin
How can i transfer this access point to my new dashboard ?
It is necessary to delete them on organization ?
Thank you very much.
4 REPLIES 4
redsector
You need to remove them from the network and then remove them from the Inventory. I don´t know if you can do this with your account when it´s not a full organization admin.
Then you can add them to an new dashboard.
The problem is: you can´t move the licences by yourself, you need help by Meraki, and this is difficult.
Thank you !
When you say " you can't move the licences by yourself", it's because i'm not the organization admin or because there is a there is a procedure that only Meraki can handle ?
You can move the license via a support case if you are admin.
If you are not admin of the current organization you have your org admin can do this via the support case.
Yes, that´s it. Exactly.
