Can I manage firewall rules by template?
kawata2
I have 3 site and 3 ssids each other.
I consider deploy same firewall rules to these sites.
Can I use the template to manage only firewall rules?
I don't want to manage with template the SSID's and the other configurations.
KarstenI
Sadly, this is not possible. Yes, having kind of "Config-Objects" that can be applied to different networks would boost productivity with Meraki. But no, that is not possible.
Workaround: Configure your rules as a JSON object on your PC and use the API to push it to all networks that need the same config.
9 Replies 9
KarstenI
Thank you for your reply.
I understood that it is impossible.
I'm going to configure each networks.
Regards,
GreenMan
KarstenI
@GreenMan wrote:
Using Network Objects may help you:   https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/Network_Objects_Configuration_Guide
On the SSID-Firewall? Does the Support have to enable that?
Hmmm - I'd never tried it on MR FW before.   It seems Network Objects applies to MX only.  Could I suggest people 'Make a wish' for Network Objects on MR too..?
KarstenI
I think I did that already some time ago, but I wished for that now again.
I'm waiting for network objects (official).
I'll try it when I get a chance to verify.
Regards,
Thank you for your reply/
Regards,
I can see the network objects functions.
If the function will be official, I will try it.
Regards,
