Building an External Captive Portal
DillonofAnch17
SO I have visited the Meraki.io documentation on how to build this using API's. My question is more around if anyone in the community has built a captive portal and collected Data with it.
For instance our Captive portal would load our e-commerce web page for login or you would sign up for an account at the time of sign up. Then once you have logged in you would be forwarded to a YouTUbe history of business video.
Any thoughts?
2 REPLIES 2
You can almost do that using the standard captive portal.
Can you authenticate against the ecommerce portal user database using either LDAP or RADIUS?  This would let you authenticate users - but not allow sign up.
You can then use the option to redirect to a specific URL after login.
JamesClifford
I'm working on a simple solution for restaurant guest wifi to record the name and email address, after consent, with a external captive portal.
It records the details with a time stamp in a CSV file on the web server.
After you authenticate it forwards you to the restaurant website.
