Blocking device for single SSID
MarcP
just wanted to block two devices from a single ssid and did that as following:
Directly after doing this, policy is showing "custom", couple of seconds later its showing blocked.
Over night, the devices were disconnected and I came back today, checked the dashboard and these devices are still in the forbidden SSIDs...
Policy column still shows "blocked", but when I select the devices and click on policy it shows following:
Within devices detail page it is showing this (like in this threat😞
So, for me it looks like this option does not work(?).
Furthermore at least one device should connect to a different SSID now, but it is not - like it is blocked for wifi in general.
Accepted Solutions
MarcP
Re: Blocking device for single SSID
Meraki support:
Greetings,
Thank you for contacting Cisco Meraki Support.
We have reviewed the information that you have shared below and there is currently a known issue around the section of the dashboard that you are currently trying to configure and is currently under investigation by our engineering team as some of the behaviour that you are noticing is unexpected. If you do have any questions in the meantime please don't hesitate to let us know
Kind regards,
5 REPLIES 5
MarcP
Does it mean it will only be blocked for internet access, not for connecting to the specific SSID?
MarcP
Meraki support:
Greetings,
Kind regards,
MarcP
Now, also got this mail from Support...
I thought, if someone is blocked, he is not able to connect. But he/she is... Only can´t reach any resources...
Can anyone confirm this? @BrandonS
BrandonS
If I understand, they are saying the clients will technically connect to SSID, but be blocked from resources based on the policy.  Is that what you are asking?
MarcP
This is what I understand, too.
But I assumed a client won´t be even able to connect to the SSID.
Thats very misleading. Altough the client seem to have a wifi connection (well, it has, but no internet connection)
My goal is to deny to connect to a specific ssid.
