Blink LEDs Won't Stop
arapheon
Hey everyone, this should be a simple question but I can't find the answer to it.  Normally the "Blink LEDs" function on the MR series works perfectly, where the AP blinks when you click it from tools, then stops when you X out of it.  In the newest network I deployed in a warehouse, I have seven MR42s that all refuse to stop blinking after pressing the button, even after I've clicked the X. I went back and checked it after two hours and the blinking continues. Firmware's updated, and the only way i can stop it is by rebooting the device.
Anyone experienced this? Any suggestions?
8 REPLIES 8
BlakeRichardson
Re: Blink LEDs Won't Stop
@arapheon  What version firmware are you running? That way a few of us can hopefully test this on our devices.
arapheon
Hi @BlakeRichardson . They are running 27.6.  It is incredibly important for them because of the warehouse setup and inability to reach the access points from high in the air.
BlakeRichardson
I'm running 27.5 so give me a few minutes, i'll update a unit, test and get back to you. I only have MR33 however.
BlakeRichardson
@arapheon  I cannot reproduce the fault on the MR33 I have, hopefully someone else with the same model AP can test.
arapheon
@BlakeRichardson thanks for giving this a shot.  I've never seen it before.  It has to be something with this network specifically because it affects every device.
That's funny.
ArturoD
I am actually facing the same issue with the "Blink LED" feature. I have MR42 APs and when I run the feature those start blinking but when I stop clicking in the "X" those don't stop blinking until I reboot the AP. An AP has been blinking for 2 days.
Hope someone knows how to stop this behavior.
MR42
Firmware: MR27.6
arapheon
Sorry it's happening to you as well! It almost completely negates the feature. It also negates the status light.
Glad I'm not crazy, but man this is annoying.
