Bandwidth shaping
Boza
Bandwidth shaping
Hi all,
I'm currently looking for a way to limit bandwidth speed in our Meraki wifi network. We are having 50+ locations, same setup on all, two SSIDs, but the problem is that not all location have same internet link.
My question are, can I globally set internet speed per SSID based on % ? I want SSID-1 to use 75% of bandwidth and SSID-2 to use 25% ?
Or do I need to go from location to location and set it manually per AP (Wireless > Firewall and Traffic Shaping > Choose SSID > apply traffic shaping rules) ?
Any other ideas are welcome!
Regards,
Boza
Bettencourt
You will need to go each Firewall & traffic shaping > Traffic shaping rules > Per-SSID bandwidth limit.
Alternatively, you can bind your existing networks to a template and do it all in one go.
https://documentation.meraki.com/General_Administration/Templates_and_Config_Sync/Managing_Multiple_...
You can only configure a specified limit, not a percentage.  It can be configured per SSID.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Global_Bandwidth_Limi...
Bettencourt
@Boza please note that the bandwidth limit per SSID is actually per AP per SSID.
As an example:  You have 30x APs and they all advertise SSID 'public', if you set a limit for that SSID to 1Mbps then you could have as much as 30Mbps of traffic.
Boza
Thank you all for your help. Solution with templates that was suggested by @Bettencourt is what I was looking for!
@cmr thank you as well for your info, I didn't know that.
Regards,
Boza
