Apple's mobile phone ios11.4 WiFi is not connected,802.1x authentication
ericliu
Apple's mobile phone ios11.4 WiFi is not connected, the authentication method is 802.1x, and sometimes the phone is disconnected. After a while, the phone will report the wrong password (but the password is correct), and then use the same The password can be connected successfully. What should I do with this question? Master is the ios version of the problem? Does Apple have official instructions?
2 Replies 2
ericliu
Has anyone encountered a similar problem?
MRCUR
Have you tried a network settings reset on the iOS device? See step #7 here: https://support.apple.com/en-us/ht204051
MRCUR | CMNO #12
