Amazon Echo - advice
bluemoon25
Anyone has advice on the combination of Amazon Echo and Meraki ? Have just replaced home Wired / Wireless with Meraki MX / MS / MR combination. So far everything is connected and running fine except the Echo.
I have iPhones / iPads / Apple and Chrome Computers / Google NEST and quite a few other wireless clients connected to the Meraki network
I have done nothing to tweak the general WiFi settings but I cannot get the Amazon Echo to hold it's connection
This has to be a pretty common combination and so I am hoping others might be able to share their own setup and any tweaks needed ?
BrandonS
I have three echos on my home Meraki network and have no particular problem.  Over a year or so I have had to restart a couple of them only a couple times, but I never bothered to consider if there was a network issue or just a glitch on the echo.
What do your wireless event logs show?  Have you looked at RF spectrum and considered the placement of the echos?
Thanks for the prompt reply.
One comment to add is that Meraki have told me to upgrade my Wireless Firmware to the latest and I have scheduled that for tonight
Meanwhile see attached Event Log for the Alexa / Echo and screenshots of the RF Spectrum which indicates a very busy 2.5G radio and a much less occupied 5G
Any more thoughts ?
so its connecting 2.4ghz. how about you run 5ghz only
Hi - thanks for the suggestion.....I think I resolved this with a combination of Firmware Upgrade to the MR33 and a move to a better location
The 2.5GHz signal is needed for a GOOGLE NEST that has no 5GHz capability but I wonder if it might make sense to create a separate 2.5GHz radio for the NEST and turn off the 2.5GHZ transmitter on the general SSID ?
