API - how to check for blocked clients
CiscoUser
I need to get all the blocked clients from the network or device. In the community there was suggested a UI solution of filtering clients by policy.
How-to-check-the-blocked-clients-list
1. Does anyone know of a way to get blocked clients using REST API ?
2. Still in API, does anyone know of a command to get all clients and their SSID (instead of one call to get client ids on device, and another call using single client id to get ssid).
2 REPLIES 2
You could ask for the group policy assigned to the client.
https://dashboard.meraki.com/api_docs#return-the-policy-assigned-to-a-client-on-the-network
I don't know if a way to return all of the clients using a specific SSID in a single API call.
I wanted to add that I noticed that unfortunately that only works for clients that are known in the dashboard. If you've added a client manually that call doesn't seem to return a result.
