API - Retrieve clients on each SSID
CiscoUser
Using api, I need to know which clients (mac/ip/identifier) are connected to which SSID.
From the API docs there is an option to get clients
api/v0/devices/[Device_ID/clients
and SSIDs
api/v0/networks/[Network_ID]/ssids
In both of them you cannot relate between a client and an SSID of which is connected to. (clients don't have ssid field, ssids dont have clients list).
Is there a way using the official API to get clients on SSID information?
Thanks in advance
BrechtSchamp
Actually when you fetch a client's details you do get the SSID:
BrechtSchamp
Thanks a lot !
Wasn't aware of this path, just what I needed ^^
CiscoUser
While at it, does anyone know of a way to get all clients(with their SSIDs) in one request?
In order to check all of them together, and avoid making hundreds of requests for a large network.
thanks again
No, unfortunately I don't. However I think Meraki will have to think about a solution for bulk requests. Because I regularly see people with this problem (running against the 5 calls per second per organization limit). Just like the dashboard the API is always evolving. Definitely make a wish about it!
