API - Get client info just by MAC
CiscoUser
Hi
To get client info via API, it seem I must know beforehand on which network or device it is on:
GET /devices/[serial]/clients
GET /networks/[networkId]/clients/[id_or_mac_or_ip]
Assuming I want to get client info only knowing it's MAC (big organization with multiple networks and devices) is there a way?
Interested in any kind of workaround you have in mind, even for partial info,
2 Replies 2
BrechtSchamp
I'm afraid the only option is to go:
GET /organizations/[organizationId]/networks
Then iterating over the results with the MAC address of the client using the GET you posted.
If the client info you want is not changing frequently you would walk over every network and dump every client to something local.  Then you could just query that local database.
Note that a client could appear under multiple networks, especially a WiFi user that travels between networks.
