AP is in a different domain and an alert is showing
Hi all. I am experiencing a problem with one of the AP's on the dashboard showing in a different domain. I have followed steps to change it into the correct domain but the change button does not show in the GUI. Is there some way of changing the AP to the correct domain with out it going offline? Its currently in a network in IE but the AP is physically in GB.
Thanks in advance.
1 REPLY 1
Re: AP is in a different domain and an alert is showing
It simply might take time for the dashboard to update. Might require a reboot. If it's still not changing then your best bet is to contact support.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
