AP enclosures
kYutobi
AP enclosures
What would you guys recommend for a gymnasium for covers/protection? Thanks in advanced. Will let you guys know what I go with. I was looking at a few but still wasn't too sure about what I wanted.
Enthusiast
5 Replies 5
Raj66
@kYutobi An MR52/53 would be a good fit for high-density deployments like Gymnasiums. However, If you fancy Wifi6, I would recommend checking out an MR45/55. #Wifi6 #WorthTheHype
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
AjitKumar
Hi
I could search following vendors who offer Covers for APs.
https://coverandhyde.com
https://oberoninc.com/products/wap-vanity-covers
Never used though hence do not know about Quality.
Also have look on following communication
https://community.meraki.com/t5/Wireless-LAN/MR52-Enclosure/m-p/10495#M1758
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
I have used these in the past, I would drill a few holes in the top and bottom to allow for airflow.
I have also used these outdoors when I needed to setup a wifi network after a natural disaster and didn't have any outdoor rated AP's on hand.
amabt
@BlakeRichardson  Would you mind sharing where you got the enclosure from? We have a site in NZ that needs an enclosure and we've struggling to find one locally.
Edit: Forgot to mention. Trying to fit an MR36 to install under an eaves so just looking for a bit of water / rain protection.
Radcliffe electrical usually has good stock of various sizes.
