AP are offline but show connected at port on switch
Porcap
I have added 4 MR36 APs to our small network.  They show as offline but I can see them connected and powered on at the switch. And are not displaying correct Ip address at switch.
The ports on switch are configured as trunk or access? Have you tested with another device connected on these ports?
4 REPLIES 4
Porcap
ports configured as access.  Have not connected anything else but its the same for these 4 ports
AxL1971
Can you ping the AP on your network
I have seen this for a while where as the dashboard states the AP's are down but they are not as I can still PING them and clients connected do not have any issues
Porcap
We found multiple DHCP servers as available.  Blocked 2 of them and the APs and other devices we're successfully added.
