802.1X
matthias95
802.1X
Hi everybody,
Is there any possibility to increase the timer for radius authentication?  For now, the switch send a Radius-MAB inquiry every 30 seconds. The log is full with rejects.
In Cisco IOS it is called "authentication timer restart 3600"
Thanks in advance,
Matthias
3 REPLIES 3
GreenMan
I'm not sure, off the top of my head, but I would say it's one to raise as a case with Meraki Support.
Thank you! I just opened a case. I'll let you know what the outcome is
KRobert
I started having the same thing when we switches over to MS switches from Cisco Catalyst. Let us know what you find. My guess is that support can do it on the back end.
CMNO, CCNA R+S
