@DerrickL wrote:
Hi All,
I'm experiencing this weird issue with port scheduling and wanted to see if anyone experiences this issue. I've checked the Meraki documentation and haven't found anything helpful.
I created a port schedule and assigned it to a bunch of ports and initially it works perfectly, but if I make any changes to the port schedule, I have to select all the ports, edit, and click the update button (without actually making any changes) for the ports to get the updated schedule. Am I missing something?
Thanks,
Derrick
I have been having a similar issue with a Group Policy that I had assigned to ports. Basically, the additional content filtering in the policy wasn't triggering at the set times. The fix ended up being basically the same as you suggested by editing the group policy and hitting save. I mentioned to the tech that this could be very problematic to identify and test since users are not likely going to report to me if their restrictions aren't happening at a normal time etc. I didn't get any particularly useful feedback to that rebuttal.
