I will listen in on this ..
We see these A LOT!! (like a zillion times a day) and I should be much mistaken if all the cables/plugs were faulty everywhere in the installation ..
Any news ?
(SW: MS 11.30)
I have got the same issue on different LANs with MS225 switches with MS 11.30 software. But only on client-ports not on uplink ports. First I thought it´s an power saving issue on the clients. Apple Mac do have the most issues.
regards
Hi @redsector ..
I only have AP's connected to the ports doing this ..
No issues on uplink ports as well as You observe ..
Will be interesting to hear what the Engineers say ?
Accesspoints from Cisco (classic) and Cisco Meraki (MR32, MR33, MR34, MR42, MR42E, MR52, MR45) are stable connected (trunk) to my Meraki network ports (software MS11.30). Also the uplink ports (to Cisco classic and to Merak) are stable.
Only clients (access) from Dell and Apple are having this issue.
This really sounds the same as the MAC flap issue on 11.x.
Or the MAC flap issue is the same as this.
If it's the MAC flap issue then the STP messages are just a byproduct of the port going down. If this is a separate and distinct issue with the BPDUs as someone mentioned then the STP messages are relevant.
I can say that, when I went to 11.22 my Cisco IP phones were going offline like crazy. I have Cisco 3905s and 8811s, also ATA-190s for analog bridge.
The MR34 and MR52 access points that I have were stable throughout the issues.
No issues with Avaya IP-phones.
I had to call support by phone to get someone to move the case forward. The phone tech said that he noticed 97% cpu usage on my core switch. I wish they expose that info in the portal, all I can see as far as health for the switch is a nice green "Healthy", meanwhile CPU is at 97% and ports are flapping in the logs. He thinks the CPU might be causing ports to go down and then generating the UDLD and STP alerts. He asked me to update to the latest (11.30) which I did this morning, but still see the same flapping in the logs, and I am waiting to a support tech to tell me what the CPU looks like now. He also cannot explain what he is seeing and thought it might be a performance bug (hence he asked me to upgrade).
To clarify, in the logs the ports that are flapping are the 16 ports that connect 3 switches to my root switch and they are only alerting from the perspective of the other 3 switches, the root switch sees no issues with the his end of those 16 connections (its own 16 ports). There are another 8 ports that connect 2 of those switches to the secondary root switch, but those are disabled (correctly) by STP and are not seen flapping in the logs. These ports are aggregated what I usually see in the logs is that a few of the individual ports alarm about becoming unidirectional (alert by UDLD, no enforcement, means BPDU packets only going in one direction), and then back to bidirectional right away. Then I see STP cycle the entire aggregate port between root, alternate or disabled. This is constantly happening on the logs, but I only see a measurable outage when lots of UDLD alerts appear together.
I'd be interesting in seeing if that high CPU continues, and that does seem like it could cause the port flap issue.
I wish we could see that in the dashboard.
According to the tech CPU was still high so he disabled some DNS inspection:
"I did notice a spike in the CPU after the update as well. I have disabled DNS and MDNS inspection on the core switch " SW1A "since we had noticed an unusual amount of DNS traffic during the pcaps taken on the switch."
I am seeing less of the UDLD alerts, but the 3-4 alerts from the last few days have caused network blips and alerts to come out at the same time. I do still see a ton of STP alerts about it changing the aggregate ports that interconnect the 4 switches, something like 4-25 times per hour with no alerts about network issues.
I also noticed that there is already a new version 11.31 thought it doesnt list this particular issue, here are the release notes:
Have you updated to 11.31? Have you noticed any change if so?
Any chance you have found a solution with Meraki yet? We seem to be having the same issue within our organization as well. Meraki Support is telling us we have bad cables, but we have already ruled that out as a possibility.
Our next step is going to be replacing it with a regular Cisco switch and see if the problem persist.
I did update to 11.31 this morning, but the STP flapping continues. Noticed this upgrade did not reboot the switches, and did not show a progress bar on the local GUI of each switch as it usually does. Also, nothing on the logs about the firmware upgrade. I really wish Meraki would make the logs more useful.
Meraki tech suggested the follwing
Hi @Matttt -.-
We still see lots of these ..
And we also tried the new switch sw, but reverted, since it did no good in the matter.
It seems that uplinks/trunks and workstation links are affected and not selective 😉
All switch-types are affected.
It bursts 10-15 entries in the log in each occurance.
We have got MS220 and MS225 switches with MS11.31 software. No uplinks are affected (to Cisco "classic" and Maraki). Only HP-inkjets, Apple computers and Dell notebooks with dockingstations are affected.
Agree..
Seems "workstations" only ..
This is the response we received when I was having the issue back in the Summer.The issue eventually stopped without me making any changes to our network or the firmware. Seems to me they have yet to find the bug that's causing all the problems everyone is experiencing.
Jumping in here.
I've got a similar issue.
I have 2 MS350-48FP where this is happening on any port with a specific Polycom Group Series 500 codec connected to it.
I have a number of other P GS500s connected on these two switches and others that are not suffering the same issue.
LLDP is not enabled on the devices.
They are not POE (I've tried disabling POE).
I've got a ticket open with Polycom and they are looking into it but I'm not sure what the common denominator is yet.
I have a very similar issue. I have a MS220 (Non-POE) with a MR42 using an external POE injector. The exact same problem is occurring and its driving me crazy. The AP will start to reboot randomly and when I check the event logs I see:
Port status change | port: 7, old: down, new: 1Gfdx |
Port STP change | Port 7 designated→disabled |
Port status change | port: 7, old: 1Gfdx, new: down |
Extremely frustrating.
AP Firmware is 26.6.1
Switch Firmware is 11.31
We manage a lot of Meraki Networks and I see this in Every network. It doesn't seem to make any negative impact, just annoying as heck. However, you folks are saying they randomly reboot, which I've not seen on any abnormal basis beyond firmware upgrades and a forced restart to beacon freeze.
Now the MR16's have a known issue of beaconing freeze, which I have been told a fix was being written, but months have past now and the product is EOL. So I don't expect this is really going to happen. They just want you to replace the older AP's
The MR18's I've seen have a similar issue with the beacon freeze as well, but it's not considered a bug???
The MR32/33's processor gets a little over-joyed with any real density impacts.
The MR42's have been very stable for us.
The MR52's is a great AP, no issue
The MR53's have had pretty serious POE issues for us. Almost all of those have been replaced with 52's. The 53's will have POE PS overheating issues in the AP. They randomly shut down due to the thermals and eventually come come back online when they've cooled down.
Outdoor AP's, no issues.. Well other than the Metric Weatherproof thread connections... If you need to run flex to them, order from europe online because you're not going to find metric flex fittings around here.
I'm always happy to hear about bug fixes, so keep up the board posts
Thanks for your feedback BNS. Really interesting to read. We also have issues where our MR32's are placed, slow internet or not responding. Meraki will not admit it's a problem with the MR32, but have offered us a "cheap" upgrade to the MR52.
Places where we have MR52's do not have issues.
I should clarify, this actually drops the codec off the network.
We discovered that it was only the MR70's (running 26.0 software) that had the issue..
All MR's are now at 26.6.1 and no noice in the logs .. 😀
Remaining "noicers" are only workstations as others see in this forum ..
Any traction on this?
@LeeVGIt depends 😀
We saw this quite a lot, but have now upgradet switch and AP software.
Not the entries only appear in association with workstations/cabled endpoint devices like printers or legacy ethernet equipment ..
We no longer regard it as an issue, since we see/receives no transmission problem tickets originating from these devices/ports.
If the guys in this forum with the cameras/video-streams gets this on their device ports, I can see the problem ..
Would love to hear if that is the case, since we are brewing on some streaming stuff 😁
Update - I now have a ticket open with Meraki support as this is affecting more ports and devices.
None of the devices currently affected are POE.
Only the Codec are actually switching to down on the switch.
@AK1info from me: The devices affected here are also non-PoE ..
What happened to me:
after planned power maintenance more than ten Meraki MS220-8P switches (firmware 11.20) within the same network never came back in terms of management. The whole network was unstable. We have mostly Meraki but also Cisco Small Business there. In order to stabilize the network I had to power off of of stack member (Mearki MS410-16). We are running L3 on this stack. After this action we could finally access Cisco SB via SSH. Meraki MS220-8P switches are red in Meraki dashboard but seem to work as switches but every 5 minutes devices connected to them facing 20-60% percent of packet loss. Powering them down and up didn't help. Meraki advise: perform a factory reset on all MS220-8P switches.
Topology: 12xMS220---2xMS410---CiscoSmallBusiness---WAN-Router
Hello
i have the same problem (only on one port)
I'm trying to switch from Port speed AUTO to a fixed speed
Is only a test
Best regards
Christian
LOG
Sep 29 11:42:52 | Port STP change | Port 24 disabled→designated | |
Sep 29 11:42:52 | Port status change | port: 24, old: down, new: 1Gfdx | |
Sep 29 11:42:48 | Port STP change | Port 24 designated→disabled | |
Sep 29 11:42:48 | Port status change | port: 24, old: 1Gfdx, new: down | |
Sep 29 11:20:43 | Port STP change | Port 24 disabled→designated | |
Sep 29 11:20:43 | Port status change | port: 24, old: down, new: 1Gfdx | |
Sep 29 11:19:33 | Port STP change | Port 24 designated→disabled | |
Sep 29 11:19:33 | Port status change | port: 24, old: 1Gfdx, new: down | |
Sep 27 23:24:40 | Port STP change | Port 24 disabled→designated | |
Sep 27 23:24:40 | Port status change | port: 24, old: down, new: 1Gfdx | |
Sep 27 23:23:29 | Port STP change | Port 24 designated→disabled | |
Sep 27 23:23:29 | Port status change | port: 24, old: 1Gfdx, new: down |
Did anyone ever get a permanent solution to this?
I'm chasing a wild turkey type of issue and keep seeing things like this in the logs of many of our switches (MS225-48FP [firmware 12.28]) I'm having a hard time not blaming the switch....our issue is related to a Mitel phone system and Mitel brand phones.
Jan 19 12:46:40 | Port status change | port: 2, old: down, new: 1Gfdx | |
Jan 19 12:46:34 | Port status change | port: 2, old: 10fdx, new: down | |
Jan 19 12:46:29 | Port status change | port: 2, old: down, new: 10fdx | |
Jan 19 12:46:26 | Port status change | port: 2, old: 1Gfdx, new: down |
