MS410 and 10 Gb Link
Kave
I made a 10Gb link between 2 x Ms410 via SFP+ but in the dashboard shows me it is 1 Gb link. i checked with 2 different SFP + brand and cisco compatible.
kav noroozi
6 REPLIES 6
BlakeRichardson
Re: MS410 and 10 Gb Link
@Kave  Under the port information can you please provide a screenshot of the SFP module information. I've provided an example from one of my devices.
Kave
My misordering, it is working well, my mistake was select the wrong switch, i need 16 x 10 Gb port and i have to choose MS 425.
kav noroozi
Kave
Thank you for your reply, Everything was ok, it was my mistake to choose MS 410 as 16x 10Gb port, i have to choose MS 425
kav noroozi
BlakeRichardson
@Kave  Owch thats an expensive mistake. Good luck and glad you worked out what it was.
Kave
Yes, it was big mistake, hopefully my Nice Manager fixed it with Meraki and we are going to change it. 🙂
kav noroozi
BlakeRichardson
Glad to hear it, we all make mistakes and I am sure Meraki wouldn't have a problem with exchanging equipment for something more expensive.
