Search instead for
powershell script for importing/exporting devices, switchport configs, ssid's, MX firewall rules
I've tried to create a powershell script to have an import / export for some Meraki stuff to/from an excel file.
It has helped me change, deploy and backup some information.
Feel free to try.
I am no programmer so in no doubt my scripting skills are lacking, but it might serve you Smiley Happy
Basically you need ;
- Your Put Endpoint (because of the redirect which causes some issues)
- Your API key
- Excel file
I've been using Visual Studio to create and troubleshoot which works quite nice.
Enjoy !
https://github.com/relaxteb/Meraki
4 REPLIES 4
Re: powershell script for importing/exporting devices, switchport configs, ssid's, MX firewall rules
the script:
#                               MERAKI UPDATE
#   This scripts can update hosts & ports in excel and meraki cloud
#region Settings
# SET TLS version
[Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls12
#endregion
#region Variables
# Import my settings
. C:\Temp\local_variables.ps1 # YOUR MERAKI API KEY !
# Import funtions
. .\meraki_functions_1.4.ps1
# API KEY
$api_key = $Meraki_api_key #ENTER YOUR API KEY HERE
# Test value
if  (!$api_key) {write-host "No API key found" -ForegroundColor Red
                exit
# ENDPOINTS FOR API / ivm 308 redirects
$get_endpoint = 'https://dashboard.meraki.com/api/v0'
$put_endpoint = '' #'https://nXXXXXXXXX.meraki.com/api/v0'
#$get_endpoint = 'https://api.meraki.com/api/v0'
#$put_endpoint = 'https://api.meraki.com/api/v0'
if  (!$put_endpoint) {write-host "No PUT endpoint found" -ForegroundColor Red
                exit
# EXCEL FILENAME
$excelfilename = "MerakiExcel template.xlsx"
$switchportsheetname = "switchports"
$firewallsheetname = "firewallrules"
$devicesheetname = "devices"
$ssidsheetname = "ssid"
if  (!(Test-Path $excelfilename))  {write-host "No EXCEL file found" -ForegroundColor Red
            write-host "Make sure to create the excel file and sheets: " -ForegroundColor Red
            write-host $switchportsheetname -ForegroundColor Yellow
            write-host $firewallsheetname -ForegroundColor Yellow
            Write-Host $devicesheetname -ForegroundColor Yellow
            write-host $ssidsheetname -ForegroundColor Yellow
            pause
            exit
#endregion
#region Functions
#endregion
Clear-Host
# Get the Organization
write-host "Getting organizations: " -NoNewline
$organization = Get-MerakiOrganizations -endpointurl $get_endpoint -apikey $api_key
write-host "Organization: "$organization -ForegroundColor Green
# Get the Networks
write-host "Getting networks: " -NoNewline
$networks = Get-MerakiNetworks -organizationid $organization.id -endpointurl $get_endpoint -apikey $api_key
write-host $networks -ForegroundColor Green
# Get the Devices
write-host "Getting Devices: " -NoNewline
$devices = Get-MerakiDevices -endpointurl $get_endpoint -apikey $api_key -networkid $networks.id
write-host $devices.count -ForegroundColor Green
start-sleep -seconds 1
# Do MENU
do {
    clear-host
    write-host "--------------------Main Menu--------------------------------------"
    write-host "1. Device"
    write-host "2. Switchport"
    write-host "3. MX"
    write-host "4. WIFI"
    write-host ""
    write-host ""
    write-host "Q. Quit"
    write-host ""
    write-host ""
    write-host "Devices:`t`t`t" $devices.Count
    write-host "File:`t`t`t`t" $excelfilename
    write-host "Network:`t`t`t"$networks.name $networks.id
    write-host "Organization:`t`t`t"$organization
    write-host "-------------------------------------------------------------------"
    $input = Read-Host "Please make a selection"
    switch ($input) {
        '1' {
            # Device
            do {
                clear-host
                write-host "--------------------Device Menu -----------------------------------"
                write-host "1. Read Devices from Excel and update API"
                write-host "2. Read Devices from API and write to excel"
                write-host "3. Get Device info"
                write-host ""
                write-host ""
                write-host ""
                write-host "B. Back"
                write-host ""
                write-host "Sheet:`t`t`t`t"$devicesheetname
                write-host "File:`t`t`t`t"$excelfilename
                $inputlevel1 = Read-Host "Please make a selection"
                switch ($inputlevel1) {
                    '1' {
                        # Read Devices from Excel and update API
                        Clear-host
                        #$devices = read-MerakiDevicesFromExcel -filename $excelfilename -devicesheetname $devicesheetname
                        #foreach ($device in $devices) {
                            write-host "Updating devices...." -ForegroundColor Blue
                            Update-MerakiDevices -endpointurl $put_endpoint -apikey $api_key -filename $excelfilename -devicesheetname $devicesheetname -networkid $networks.id
                            # Max 5 Calls per second
                            # See https://documentation.meraki.com/zGeneral_Administration/Other_Topics/The_Cisco_Meraki_Dashboard_API
                            Start-Sleep -Milliseconds 200
                    pause
                    '2' {
                        # Read Devices from API and write to excel"
                        write-MerakiDevices2Excel -devicearray $devices -filename $excelfilename -devicesheetname $devicesheetname
                    '3' {
                        # Get Device info
                        Clear-host
                        $Inputdevice = Read-Host -Prompt 'Enter the devicename'
                        Get-MerakiDevice -endpointurl $get_endpoint -apikey $api_key -switchname $Inputdevice -networkid $networks.id
                        pause
            } until ($inputlevel1 -eq 'b')
        '2' {
            # Ports
            do {
                clear-host
                write-host "--------------------Switchport Menu -------------------------------"
                write-host "1. Read Ports from Excel and update API"
                write-host "2. Get Switchports from API and write to excel"
                write-host "3. Get port info"
                write-host ""
                write-host ""
                write-host ""
                write-host ""
                write-host "Sheet:`t`t`t`t"$switchportsheetname
                $inputlevel2 = Read-Host "Please make a selection"
                switch ($inputlevel2) {
                    '1' {
                        # Read Ports from Excel and update API
                        Clear-host
                        write-host "Getting ports from excel"
                        $ports = read-MerakiSwitchPortsFromExcel -filename $excelfilename -switchportsheetname $switchportsheetname
                        foreach ($port in $ports) {
                            if ($port.Switch) {
                                    if ($port.switch -eq $device.name) {
                                        $serial = $device.serial
                                        write-host "Updating port:" $device.name $port.number $serial `
                                            "name:"$port.name  `
                                            "tags:"$port.tags `
                                            "enabled:"$port.enabled `
                                            "poeEnabled:"$port.poeEnabled `
                                            "type:"$port.type `
                                            "vlan:"$port.vlan `
                                            "voicevlan:"$port.voiceVlan `
                                            "allowedVlans:"$port.allowedVlans `
                                            "isolationEnabled:"$port.isolationEnabled `
                                            "rstpEnabled:"$port.rstpEnabled `
                                            "stpGuard:"$port.stpGuard -ForegroundColor Green
                                        Update-MerakiSwitchPort -endpointurl $put_endpoint `
        -apikey $api_key `
        -port $port.number `
        -serial $serial `
        -name $port.name  `
        -tags $port.tags `
        -enabled $port.enabled `
        -poeEnabled $port.poeEnabled `
        -type $port.type `
        -vlan $port.vlan `
        -voicevlan $port.voiceVlan `
        -allowedVlans $port.allowedVlans `
        -isolationEnabled $port.isolationEnabled `
        -rstpEnabled $port.rstpEnabled `
        -stpGuard $port.stpGuard
                                        write-host "Waiting 100 milli seconds" -foregroundcolor yellow
                                        Start-Sleep -Milliseconds 100
                        pause
                    '2' {
                        # Read Ports from API and update Excel
                        Clear-Host
                        write-host "Getting devices from API"
                        write-host "Getting switchports from devices"
                        $switchports = @();
                            if ($device.Model -like '*MS*') {
                                write-host "Found Device: " $device.name -ForegroundColor Green
                                $switchports += Get-MerakiSwitchPorts -endpointurl $get_endpoint -apikey $api_key -switchserial $device.serial -switchname $device.name
                        $switchports  = $switchports | Sort-Object -Property @{Expression = {$_.switch}; Ascending = $false}, number
                        write-MerakiSwitchports2Excel -filename $excelfilename -switchportsarray $switchports -switchportsheetname $switchportsheetname
                        pause
                    '3' {
                        # Get port info
                        Clear-host
                        $Inputport = Read-host -prompt 'Enter Switchport'
                        Get-MerakiSwitchPort -endpointurl $get_endpoint -apikey $api_key -switchname $Inputport -port $Inputport
                        pause
            } until ($inputlevel2 -eq 'b')
        '3' {
            # MX
            do {
                clear-host
                write-host "--------------------Firewall Menu -------------------------------------"
                write-host "1. Get Firewall Rules from API and write to excel"
                write-host "2. Get Firewall Rules from excel and write to API"
                write-host ""
                write-host ""
                write-host ""
                write-host ""
                write-host ""
                write-host "Sheet:`t`t`t`t"$firewallsheetname
                $inputlevel3 = Read-Host "Please make a selection"
                switch ($inputlevel3) {
                    '1' {
                        # Get Firewall Rules from API and write to excel
                        Clear-host
                        $firewallrules = Get-MerakiMXFirewallRules  -endpointurl $get_endpoint `
        -apikey $api_key `
                        write-MerakiMXFirewallRules2Excel   -filename $excelfilename `
                                                            -firewallrulearray $firewallrules `
                                                            -firewallsheetname $firewallsheetname
                        pause
                    '2' {
                        # Get Firewall Rules from excel and write to API
                        Clear-Host
                        Update-MerakiFirewallrules  -endpointurl $put_endpoint `
                                                    -apikey $api_key `
                                                    -firewallsheetname $firewallsheetname `
                                                    -networkid $networks.id `
                            pause
                    '3' {
                        # MX option 3
                        pause
            } until ($inputlevel3 -eq 'b')
        '4' {
            # WIFI
            do {
                clear-host
                write-host "--------------------WIFI Menu -------------------------------------"
                write-host "1. Get SSIDs from API and write to excel"
                write-host "2. Get SSIDs from excel and write to API"
                write-host ""
                write-host ""
                write-host ""
                write-host ""
                write-host ""
                write-host "Sheet:`t`t`t`t"$ssidsheetname
                $inputlevel4 = Read-Host "Please make a selection"
                switch ($inputlevel4) {
                    '1' {
                        # Get SSID from API and write to excel
                        Clear-host
                        $ssids = Get-MerakiWifiSSIDs  -endpointurl $get_endpoint `
        -apikey $api_key `
                        write-MerakiWifiSSIDs2Excel   -filename $excelfilename `
                                                            -ssidarray $ssids `
                                                            -ssidsheetname $ssidsheetname
                        pause
                    '2' {
                        # Get SSID from excel and write to API
                        Clear-Host
                        Update-MerakiWifiSSIDs  -endpointurl $put_endpoint `
                                                    -apikey $api_key `
                                                    -ssidsheetname $ssidsheetname `
                            pause
                    '3' {
                        # SSID option 3
                        pause
            } until ($inputlevel4 -eq 'b')
} until ($input -eq 'q')
# Do garbage collection
[System.GC]::Collect()
i could not paste the functions so you have to download them Smiley Happy
I haven't tested it, but thanks for the share!
I spend most of my day using powershell, but I found it more desirable to brush up on my Python skills than figure out how to tackle the Meraki API with powershell. I'll have to check this out, because it might streamline the way I do things if I can use add API calls to powershell scripts I already have. Thanks for the example.
