Search instead for
missing attributes in API ?
Hi all,
I'm playing with the API to have multiple ports configured.
Now i don't see the fields/attributes for the Access policy to configure it from the API
I've checked https://dashboard.meraki.com/api_docs#update-a-switch-port but no options.
Am i missing something or is the API missing these fields ?
tnx !
Re: missing attributes in API ?
Are you talking about switch ports?
It's there.
  "number": 1,
  "name": "My switch port",
  "tags": "tag1 tag2",
  "enabled": true,
  "poeEnabled": true,
  "type": "access",
  "vlan": 10,
  "voiceVlan": 20,
  "isolationEnabled": false,
  "rstpEnabled": true,
  "stpGuard": "disabled",
  "accessPolicyNumber": "1234",       <--------
  "linkNegotiation": "Auto negotiate"
Hi !
I mean the MAC whitelist, Sticky e.t..c.
That is what i am missing
If you GET a switch/port that does have a MAC white-list or sticky configure, does it show that in the results?
I wonder if so, maybe you could reverse engineer it when you do a PUT and see if it works. Only one way to find out =)
Otherwise you probably won't be able to do it via API (yet).
Nolan Herring | nolanwifi.com
TwitterLinkedIn
Indeed, we have to wait i guess ? Or can we request some functionality somewhere ?
You can make a wish threw your dashboard.
Feel free to toss into that wish, 'solve world hunger'.
TwitterLinkedIn
