Search instead for
imageUrl field in MV webhook alert
Hi there,
What is the "imageUrl" field in MV webhook alert for?
Even though I tried to access to that URL, access denied and don't know what that is.
3 REPLIES 3
Re: imageUrl field in MV webhook alert
Hi @maizumi!
That is a new feature and enhancement to the Motion Alert – You can read more about it in our documentation via the link below, but in a nutshell it provides you with a link to the image that was captured when the motion event was triggered. If you are encountering a situation where the image was not accessible, please open a case and report that issue, so we can investigate. We'll also get this attribute defined and added to our webhook API documentation so it's clear.
https://documentation.meraki.com/MV/Advanced_Configuration/Motion_Alerts
Best,
The Meraki API team </ >
Hi Tony,
Thank you for your comment. Everytime I get webhook regarding motion alert, url link isn't accessible.
So I will open a case for it.
Regards,
Masaaki
Just curious, what model of camera do you have and is the "restricted bandwidth mode" setting enabled or disabled?
