Search instead for
Usage over time data
I think I know the answer to this, but I wanted to make sure I was not missing something deep in the API. We have a customer that wants usage data for their ~30 locations on roughly a monthly basis. The information is in Organization > Summary Report under Usage Over Time for the chosen network and chosen time period. What I'd like to do is to gather this information via the API so that it can be put in a CSV file that will eventually be merged into BrightGauge. So far I have not been able to find anything in the API that seems to provide access to this information. My guess is that Meraki has not created an endpoint for this yet. Is this correct?
If this is the case, I put in a wish a while ago for this functionality.
Thanks!
4 REPLIES 4
Re: Usage over time data
I'm not seeing anything in the API that would meet your requirements. But maybe, as an alternative, you could use SNMP to get this data? I know the MX's can tell you Tx and Rx octects via SNMP. I' m not sure about other devices though.
I will look into this and see if it is an option for getting the data we need. Thanks for the help!
Would using the "Export to Excel" be an option?
I am already using the export option to get the usage data. But since I have to do it site by site and then pull the data from the spreadsheet (more than 2000 rows per site) for around 30 sites and get it all in one file, I was looking for a more automated way of collecting it.
