Search instead for
Snapshot link from API not working
I'm trying to use the snapshot API, and the initial call to get the link is working fine. However, the provided link issues a 401 Unauthorized (via Postman) and simply returns "error" in a web browser.
What credentials are expected for this URL to resolve?
The camera is currently set to continuously record, so I'm sure there's an image available. I'm not specifying a timestamp though. I'm waiting at least a minute (sometimes several) before hitting the snapshot URL after requesting it initially.
4 REPLIES 4
Re: Snapshot link from API not working
401 usually means bad credential. Are you using the correct API key for what you're doing? Are you sure it's being sent correctly?
Does the API key for the user account being used have access?
I’m using the same API key that I used to request the snapshot URL. It’s saved in Postman, so I know it’s not a copy/paste error or anything.
Just browsing
Just to let you know that I get a 404, when I try to get the image returned in the JSON below:
"expiry": "Access to the image will expire at 2019-09-06T03:28:11-07:00"
