Search instead for
Snapshot API not working 404
Hello there
I am trying to make a POST request using node to the snapshot API for the MV22 camera
But i only manage to get a 404
This is the URL i am using
https://api.meraki.com/api/v0/networks/NETWORK/cameras/SERIAL/snapshot
Any help would be appreciated, because i don't find the answer
Accepted Solutions
Re: Snapshot API not working 404
Ok, after using the shard url it started returning a 400, so then I removed the content type application/json and it worked.
This returns me the URL for the snapshot, after trying to make a GET request to this url it gives me a 404 error again. I don't find any documentation at all about how to get this snapshot or what headers does it expect
The problem seems to be that when you request a snapshot, this snapshot is not inmediately available, you have to wait 5 seconds before being able to download it through a GET request.
So what i did is to wait 5 seconds after requesting the snapshot, then fetching it, and it works
To summarize:
- Request the snapshot to the Shard url
- Do not use content type, there is a bug
- Wait 5 seconds
- Download image
9 REPLIES 9
What are you calling it from?  Code? Postman?
Have you tried calling it using the specific shard url?
From code, which one is the shard url?
This sounds familiar...
It's a more specific one with a number.  See the note about "redirect" on this link :
https://documentation.meraki.com/zGeneral_Administration/Other_Topics/The_Cisco_Meraki_Dashboard_API
To summarize:
- Wait 5 seconds
- Download image
Thank you!!!
It would really be nice for this to be added in documentation somewhere.
Thanks for reporting back!
Just browsing
Hi folks, well, as of today, the API is currently returning a 404 when I perform a GET on the URL of the image returned in the JSON response from the Camera Snapshot API.
I waited much longer than  5 seconds to try to GET the image. The URL to the image was in the format of:
https://spn3.meraki.com/stream/jpeg/snapshot/b9a47b53df1a68b9VHN2Q1NmNlZTYxO......
