Search instead for
Set primary uplink for MX using API
HI
Is there any way of setting the primary uplink on an MX using API?
Networks and Rants
3 REPLIES 3
Re: Set primary uplink for MX using API
I can't see any API to do this.
Should be https://dashboard.meraki.com/api_docs#update-the-management-interface-settings-for-a-device right?
edit: missed that keyword “primary uplink“
Unfortunately, this is not available as of yet. Please go ahead and leverage the "Make a Wish" button on your dashboard to submit your feedback. This would be really useful and we might come up with a feature like this.
Cheers!
Raj
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
