SM Api
jared_f
SM Api
Hi All,
Hoping someone maybe has run into a similar situation that I am and/or can provide some advice. We are using Meraki MDM as our management solution and we are starting to use VPP user based assignments. This requires a lot of work on my end because I have to either enter the user manually or upload a CSV downloaded from the owner's list in SM.
Luckily, it allows us to upload that CSV. Does anybody know how I could use the dashboard API to add the users to the user section of VPP via the API?
Future thanks for any help,
Jared Flitt
1 Reply 1
RodrigoC
Hi @jared_f,
Unfortunately not at this time. You can find a detailed list of all the things you can do with the API by going to the Help >API docs page on Dashboard.
That being said, I think this would be a great feature request! 😃
