Search instead for
RF spectrum
RF spectrum
Hello - I'm looking to pull down the channel utilization for all APs with the API.  I couldn't find this option anywhere in the docs.  Is this option available?
The goal is to keep this data locally and put in a Grafana dashboard along with the MR throughput.  Then I can look back and see the channel utilization during peak usage rather than having to pull it up in realtime.
I also dug through available SNMP fields with no luck.
1 REPLY 1
Re: RF spectrum
Nope I don't think that info is available through API yet. Have a look through the Wireless Health endpoints here:
https://documenter.getpostman.com/view/897512/meraki-dashboard-api/2To9xm?version=latest#69c2d6cd-a3...
Maybe that'll help you achieve similar results.
